Stand Starting a Mariner 55el Help!!!!
Arsytee
Hi, I've just bought a Mariner 55El 1987 (pretty much a yamaha so I've been told). Its on a stand in my yard so I obviously want to test it to get it running. I connected the battery - to the large bolt on top near the flywheel. On the solenoid, there was already a wire coming from the bolt which had + written on it so connected this to my battery positive. The solenoid then has a black wire coming from the bottom of it which goes in to the other wire terminals on the left side of the engine. On top of the solenoid is a brown wire which goes directly in to the harness which goes to the controls. The previous owner had split this brown wire and run another lead off it. He told me that when this is touched to earth the engine will start, however this doesn't work. What I can't understand is where the solenoid gets its positive power from to active the switch. Can someone help me please!
carholme
Re: Stand Starting a Mariner 55el Help!!!!
Something sounds pretty bastardized there. Do you have the engine s/n?
Gerry
Arsytee
663 l 318317 h
Arsytee
Gerry, my serial number is 318317, according to the list you posted that makes it 1987, not quite sure what you were looking at.
55 EL 663-318051 - 663-318398 1987 (Copied from you link)
Arsytee
Anyhow, I've now been to my local marine and sorted the problem with thanks, as you suspected the previous owner had messed around with the wiring and I've now put it back to how it should have been originally!
carholme
Arsytee;
My apologies for the brain fart, the reason I wanted the s/n was too send you the wiring diagram. Glad you got it sorted.
Gerry
Arsytee
Gerry, if you have the wiring diagram please could you still send it to me. I think I am still going to need it.
Arsytee
Have PM'd you.
