Re: stalls when put in gear,idles great
One of the first symptoms of fouled plugs is difficulty in starting and stalling at throttle-up.
So, even though it seems to start well, the first thing to do is to pull the plugs and clean them. Since they are surface gap plugs, cleaning with a Scotchbrite pad (green scrubee) is easy.
Then, if you still have the problem it really helps to have a tachometer. You need to check to see that the idle in gear, in the water is about 700-750 RPM. Less than that and these engines tend to stall on throttle-up under load.
If you do not have a tach, do not want to buy one, and can not borrow one, then try raising the idle just a "smidge" Try about 1/8 to 1/4 turn in on the idle stop screw at the bottom half of the control tower.
Quickly move the control lever to snap the engine into gear; do not ease it in thinking to be gentle with it. This just wears the drive dogs. You should hear a definite "clunk" when the engine is put into gear in the water.
