Running lean. Tweek carb screews. If you don't know how then go out 1/8 on the idle mixture screews. If no help then try in. Still no then count the turns and pull them out. Spray carb cleaner or sea foam in the hole to clean the idle jets. Pull the bottom/main jet screew and spray it while your at it. That's about all you get when you pay for a carb rebuild. Throw in a fresh set of plugs and gear lube and they charge $600.
