SweeperForce
Thread starter- Joined
- Feb 7, 2010
- 487
Hello,
Rather than reserect and old thread I'd thought I'd start a new one. Here's whats going on:
At the dock before we go out, the motor starts up nice and idles fine while it warms up. Underway through the no wake zone she runs great. Then in open water I can go right to wot with no problems. So far everything is great. My problem is coming back to the dock. As soon as I hit the no wake area and reduce my speed to a craw it stalls. If I just turn the key it cranks but won't start, I need to start it at 1/2 throttle in neutral, the same way I do for a cold start. It does this everytime I come back, it's like she don't want to be put back on the trailer.
I've been told it might be fuel recirulation system and to do a compession test, so here's what I did:
Comp test- good
Plugs -good
Fuel pump diapraghm - good
Fuel pump screen - clean
In-line fuel filter- small amount of fine debris
Seafoam treatment
Fresh gas with 50:1 two stroke tcw3 oil
Now I replaced all the fuel lines this spring with high pressure fuel injection hose(I know overkill)New hoses to and from each pump and the hoses feeding the carbs. Spring of 2011 I replaced the primer bulb. The only hose I did not replace are the small hoses in the pictues below.
Any help on this problem would be great.
Thanks,
Tom
Comp test- good
Plugs -good
Seafoam treatment
Thanks,
Tom
