Cootkiller
Thread starter- Joined
- Mar 9, 2011
- 7
I have a 2005 Volvo Penta 5.0 OSI-EF that stalls coming off of plane. I have had idle issues for awhile and just can't seem to nail it down. So far during the troubleshooting process I have had the boat scanned with no codes, replaced the IAC Valve, Throttle Position Sensor, Temp sensor for the ECU and the PCV Valve. I checked for vacuum leaks none found changed the plugs, fuel filter. I have checked the butterfly in the throttle body its good, what am I missing? The boat starts fine on the trailer as well as first start in the water, I am missing the warm-up cycle when cold starting the engine idles at 650-700rpms. Just a thought do you think it could be a stuck injector flooding the engine when I come off of plane as well as causing a rough idle, I could run some Seafoam through it with the small fuel tank I have.
