Can anyone advise on the use of the stainless<br />swivel pin that I see at hillmarine.com.<br />Seems like a no brainer and it is priced<br />less than OEM part 98230A1.I have a broken gimbal<br />ring and need to replace swivel pin too because of <br />pitting around the seal area of the pin.Gimbal<br />ring broke into three peices at the corners of the square hole on top.<br />Could I have caused this by over torqueing the u-bolt in an attempt to remove steering play?<br />96 Bravo III, 7.4L, fresh water, 24' Mariah.<br />800 hrs. since purchased new.<br />No serious problems until coupler splines wore<br />to a "pointy" wear pattern and required replacement, and now this.
