Re: stainless prop question
A stainless prop of similar design and same pitch would typically give you a better hole shot and will have a bit more rpm in the top end, so might be faster.<br /><br />Props are so variable though, that it's hard to generalize.<br /><br />One thing about the Big 3-cyl's is that they don't like to rev beyond the recommended rpm range, so don't get a prop that will ovverev the motor.<br /><br />If you stay within a pitch-size of your current prop, you should find something that'll work well for you. <br /><br />For example, a 20" stainless would likely do well on this motor. A 21" depending on the design would probably work too. <br /><br />But don't go with less pitch than your current prop, guarantee it'll rev up too much.<br /><br />HTH...........ed
