Stainless prop bow lift?
steelespike
Can anyone tell me how a stainless prop produces more bow lift.<br /> Is it simply a more efficient design providing better push or some mysterous physics formula?
Dhadley
Re: Stainless prop bow lift?
Some are bow lifters, some stern lifters and some have overall lift.<br /><br />It's done several ways. Rake angle, placement of cup, blade design etc.<br /><br />Yes, prop design is very much a mysterious art.
gatorred
Dhadley the prop shop guy said someting about bow lift with adding cup to my prop,I just want it fixed hay I want full power? i set the carb's back so they don't open fully he said add cupping would help it
Dhadley
Gregg, as usual it's hard to understand you. Not being mean but its hard to answer you if we cant understand you.<br /><br />Adding cup in the right place will produce bow lift. <br /><br />Setting the carbs so they dont open fully is absurd. Great way to burn a piston. Especially if you're adding bite to the prop.
gatorred
that the way the dealer did it wouldn't open all the way on carb set I knew that about the piston's thing, when I run it I should set the carb's like they should be I got the prop back monday after adding cup and working on tip's of blades <br /><br /> http://photobucket.com/albums/f325/gatorer/omc-stuff/xp150/?action=view&current=catstuff_0001.jpg <br />before cup not that good pic<br /> http://photobucket.com/albums/f325/gatorer/omc-stuff/xp150/?action=view&current=DSC00066.jpg <br />more like first <br /> http://photobucket.com/albums/f325/gatorer/omc-stuff/xp150/?action=view&current=Pict0002.jpg <br />after worked on
