Jason89sunbird
Thread starter- Joined
- Sep 5, 2011
- 59
1) Performance issue you are trying to correct.
Fastest plane speed. Bought boat from my parents with michigan aluminum 18" 4 blade prop. Planed in over 10 secs (I quit counting, annoyed) I felt it when it had volvo 19" 3 blade and it was worse. When they bought the boat it was 5yrs old and had under 60 hrs. It would get to 50 mph in calm to mild chop. Just took forever to plan.
After reading Craze1Cars post http://forums.iboats.com/non-repair...-adding-4bbl-5-0l-volvo-gl-vortec-396275.html I installed carb and spacer it helped my plane but not enough. My deep hull boat wouldn't plane nicely.
I installed nauticus SX smart tabs, boat planed in under 3 secs. Best thing I have ever did to boat
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch
Installed a friend's 14.5 x 21 4 blade aluminum. Planed in under 5 secs
4) Wide open throttle RPM and speed with an average load (very helpful)
4400 rpm 52mph in about 6" chop
5) Engine/drive make, model, year, and HP
Volvo 5.0 GL 2003 220hp
Mods, 4 bbl marine 4175, 3/4 inch wood 4 hole spacer, total timing 32 degrees, iridium plugs, Taylor plug wires, new BWD dist cap and rotor.
6) Boat make model, year, length and weight
2003 reinelle 200 LSE 19' 7" 2850lbs empty. So 3500lbs on the water.
My question is will the stainless be worth the money. 21 aluminum gets 4400 rpm, can the stainless plane faster and get more rpm or should I go with a 20 aluminum because I'm cheap lol
