Spun prop?
Moocher
Motor runs fine in the driveway, but jumps when trying to push my heavy welded 1448 jon. Will a spun prop jump at low speeds? Once it kicks in the motor runs like a top and pushes the boat great. I have another prop that I'm gonna put on and test, but I cant get the dang nut off. Letting it soak and gonna try again tomorrow.
Mi duckdown
Re: Spun prop?
Not sure what jumps, means. what size motor? Put a piece of 2x4 between prop vent plate to stop prop from turning to assist in removing nut.
WIMUSKY
Re: Spun prop?
It's not trying to jump out of gear? I had that happen on an older 'rude when it was under a heavy load like getting on plane...
Texasmark
Re: Spun prop?
Remote controlled? If so, check for misaligned linkage...not engaging far enough in F gear. On Mercs, the barrel on the end of shift cable at the engine is threaded to move up and down the cable adapter to change the position of the shift lever.
Mark
Moocher
Re: Spun prop?
Sorry, forgot to give info about the motor. Early 80's 25hp tiller.
