Chavez1978
Thread starter- Joined
- Apr 11, 2012
- 55
So I spun the hub on Friday...took the old prop in 14 3/4" diameter, 20 pitch. It was an old style press in hub...rubber was shredded. (apologize in advance this was the only picture I took...I wasn't thinking I might need more to demonstrate the damage - or post for help)
Guy at the marine shop said it would have to be sent off and rebuilt, or I could buy a new prop with a drop in hub. Will the flo-torq hubs not replace an old press in style? Do they not fit for some reason if you can clean out the old rubber? I'm curious because just looking at it, it seemed it would...it wasn't until this morning I started thinking about that.
I ended up buying a new prop, but probably not too late to take it back I suppose if I can just fix the old one with a replaceable hub in stead of rebuilding.
240 HP Alpha One, Gen II Outdrive
5.7L Mercruiser V8, 350 cu-in (5.7L 350 MAG ALPHA)
