Spun my first prop hub
54fleetwin
Well for those that dont know, I purchased a '58 Fastwin for $50 and was given another fastwin, I mixed and matched parts to get 1 great motor.
I installed the better of the 2 props only to spin the hub 2 miles from the ramp, thankfully I just happened to have the other prop with me.
Beached the boat and switched the props and away we went.
How much does getting the prop fixxed cost?
So I went from a using a Fleetwin 7.5 to a Fastwin 18
Hmmm.... I wonder which is faster
HighTrim
Re: Spun my first prop hub
I have found that the price of props is so low now, it is hard to not simply purchase a new one. I have not re hubbed a prop in a while now. The 2 piece props are handy, with seperate hub and blades, so that if you blow a hub, you simply replace the hub, break a fin, replace the blade section.
54fleetwin
Well the nicer of the 2 props is an OMC prop, really nice, this is the one that spun the hub.
The other prop is a Columbian, anyone know about these?
What is the stock pitch?
Auxlarry
I just had my S.S. three blade re hubbed for $100. Much cheaper then the price of a new one. When I got it back the entire prop looked like brand new. I keep a spare aluminum with the hub insert in the boat just in case. Spend way too much time on the water to get stuck due to a prop failure!!
capt.rick
Just had one done last July. to rehub only was 52 dollars, to resurface that was 90.00. had it resurface in april.
ocenpro 225
lindy46
Last one I had rehubbed was $45.
Sixmark
Master Chief Petty Officer
I'm glad I can still get my props done for $39. It by far beats the price of a new one.
