BeerMonkey
Thread starter- Joined
- Jun 8, 2008
- 72
after looking around here to find whats wrong with my 89 40hp evinrude it seemed that the clutch dogs were bad (seemed to be poping out of gear at higher speeds) so i took the lower unit to a shop to have looked at and he did a quick test of turning the drive shaft and putting a block of wood between the prop and the lower unit and the shaft spun while the prop was being held, he said that was prob what the problem was. we pulled the prop and you could see where it was spinning the metal is actully ground down on the prop. could this explain the clunking/poping out of gear? i think for as cheap as props are i should just try a new one (old ones bent a bit anyway)
whats anyone think?????
