spring under shift cable
wtg2320
can someone please tell me what the spring is underneath the bolt on the shift cable. is it something that needs to be pressed down when I'm adjusting the shift cable. basically I need to know if I need to have the bolt all the way down everytime I test or can I not have that spring press down and keep doing adjustments.
Bt Doctur
there is no need to push down on the shift interrupter arm , all adjustments are done without moving it.
