Re: spray in vs pour in place foam
last time I checked
http://www.fiberglassservices.com/ had 2lb pour foam for 48.00 for a 2 gallon kit (1 gallon each part) which does about 8 cubic feet. They sell it in quarts,gallons,5 gallons, and 55 gallon drums. Also comes in 2,4,8,16 lb varieties. I would use pour in, just cuz I know thats what will work in boats. For max floatation, use 2 lb the higher the lb rating, the more structure support it gives, but the less floatation, at least that is my understanding of it.<br /><br />if foaming fuel tanks, you need at least 4 lb to meet USCG regulations but I don't know Canadien laws.<br /><br />The pourable stuff is polyurethane as well but not sure if its the same.<br /><br />Also don't get it on your skin, its a pain to get off.<br /><br />I would use pourable just because you can take your time when doing it, if you put to much in a closed space, it can "overexpand" and break things apart, possibly cracking the hull
