Silver Heels
- Apr 28, 2008
- 125
Hello,
I've got a 1970 14' Lund and a 1973 20 hp Johnson short shaft. When running the boat at a high speed, water tends to splash/spray up from behind the transom on either side of the motor and run down the inside of the transom. This happens with people on board and sitting forward and when its just me. The correct trim for the boat is with the motor all the way in, and changing that only exacerbates the problem as it allows the transom to go lower as the boat is no longer level, so problem is not the trim. Other than a bandaid fix like some spray shields, is there anything else I can do?
Thanks
Thanks
