Sport Jet Blues
backwater dawg
Ok now I know why my 1994 Merc sport jet 90 was not going as fast as it once was. I thought the Impeller was wearing out and maybe due to replace---Oh I wish---we took the housing apart and found a 2" hole and very severe wear marks where the impeller rides---time for a new one--is it possible to find a used one or is that just aking for more trouble
Zamboni
Re: Sport Jet Blues
Wear rings aluminum-saw guys on old sportjet site posts of 'relining' it with JB weld....seemed that worked well for them. They applied with a spatula, little oversized and used the impellor to shave the extra JB weld off for tight fit.
I've done a few using aluminum epoxy, last 2 I used marine tex 2 part epoxy and it stuck well. I used a jig and large lathe to turn a tight fit-any local machine shop could do this with $10 of epoxy and it'll run better than it came from factory. No need to buy new wear ring, its expensive since its 1 peice large casing.
cujo31
backwater dawg
Re: Sport Jet Blues
Thanks for the reply--the only problem is it also has a hole busted out on the cone shaped end where it looks like oil is supposed to be---so I think this housing is shot
Zamboni
Re: Sport Jet Blues
Cone shaped end is stator, it does contain gear oil. Its seperate from wear ring housing....strange for it to break.
PM me an email addy if you want a shop manual-should help.
backwater dawg
Re: Sport Jet Blues
I also think its strange to have a hole in the end ---but there is about a 2" hole in it--I'm going to order a new houseing and wear ring--my wife works at a boat dealer so I can buy parts close to cost--that helps--my question is--should I replace the impeller with a merc part or are ther better preformance impellers on the market???
backwater dawg
Re: Sport Jet Blues
OK-now I've bought all new parts and am replacing the Impeller and housing---what type of oil do I have to use--it looks like like there is a res the front of the shaft and the back part that broke--thanks
