Sport jet 90 fuel pump pulse connection?
Daremo
Working on a Sport Jet 90.
Noticed that after installing the motor I forgot to reconnect a hose for the fuel pump. I have the inlet from the fuel system, and the outlet to the carbs connected, but I didnt notice the pulse hose connection and thats probably why I cant get it to idle :redface:
Thing is, I am not sure of its correct routing. There is a crankcase vent/fitting right above the oil pump, and there is also a fitting on the carb inlet shroud on the right hand side at about the bottom carb. So I currently have those 2 connected together, I am thinking I forgot to put a "T" in and all three should be connected. Is this right?
The manual for this thing is terrible for systems. Doesnt show hose connection layouts for anything except for the recirc.
