I forgot you have a sportjet so you cannot tilt the motor.Thank you for your suggestion. I do not think I will be able to change (level) the piston. The pistons run parallel to the ground - the piston tops are vertical. If I understand what you are suggesting correctly, I would have to remove the motor and hang it sideways for a day - I don't think i can do that.
