Sport Jet 175 - issue with stop circuit
rossman21
Getting no spark with the black/yellow connected. If I disconnect the black/yellow, the engine starts fine.
Where do I begin to troubleshoot this?
rossman21
Faztbullet - how do I test if it is the key or kill switch lanyard?
I have a multimeter and a DVA adapter - where do I begin to troubleshoot this issue?
Faztbullet
I myself would start at the kill switch...it should read open with lanyard installed and closed when removed.
rossman21
Thank you Faztbullet!
I removed the lanyard kill switch and using the (sound) continuity selection my multimeter, found the kill switch no longer worked. Replaced it for $20 and that solved my problem.
Thank goodness the problem was not my neutral safety switch - it looks like my 1997 Sea Rayder's neutral safety switch is connected to the throttle and is basically impossible to get to.
Thanks Again!!!
