Sport Jet 120. No spark.
Baja120
Re: Sport Jet 120. No spark.
Did a compression check. All four had 150lbs. Im now backing it in to neighbors pond to start it or try to start it.
kend301
I still think you have some wires crossed , check the switchbox to coil wires , they should be as follows :
Green to cyl 1
Green/white to cyl 2
Green/red to cyl 3
Green/black to cyl 4
dropem631
Zep is right they were plagued by stator problems , Post up which stator you have ( red or black) and I will post ohm readings for that one . One quick way to tell is the black stator has red and blue wires coming out of it going to the switch box and the red stator has green/white and white/green wires running to a rectifier then blue to the switch box. BTW if you do have a black stator I would replace it regardless of test results, It will fail .
good day kend301, i have the same issue with my boat, no spark. i have the black stator (im thinking) i have red/white line and blue/white line wires coming out under flywheel. there is also a yellow wire. i was wondering if you guys new where to buy the red stator cheaper then 300.--
before it cranked then start but shut off after a few time i got it running drove back to dock, turned it off and tried to start it and got nothing, i bought new plugs and fuel filter, installed today thinking the plugs wher bad and thats why it didnt run. so i went back to the dock and noticed there was no spark.
i have a auto ranging multimeter as pictured below. is that the right tool. to test just want to make sure.
boat 95 sea rayder f16
motor is the powerjet 120
im kinda lost on how to test this stator thanks for all you guys help in advance.
dropem631
Here is some info to get you started :
Four Cylinder Engines
(1991-1996)
Four Cylinder Engines Using a Single Switch Box and Four Ignition Coils
No Fire At All:
1. Disconnect the black/yellow stop wires AT THE PACK and retest. If the engine?s ignition now has spark, the stop circuit
has a fault-check the key switch, harness and shift switch.
2. Disconnect the yellow wires from the stator to the rectifier and retest. If the engine has spark, replace the rectifier.
3. Check the cranking RPM. A cranking speed less than 250-RPM will not allow the system to spark properly.
4. Check the stator resistance and DVA output as given below:
Flywheel with Bolted in Magnets
WIRE Read To OEM RESISTANCE CDI RESISTANCE DVA
Blue Blue/White 5000-7000 2200-2400 180V or more
Red Red/White 125-155 45-55 25V or more
Flywheel with Glued-in Magnets
Force Troubleshooting
Blue Blue/White OHMS :3250-3650 DVA: 180V or more
Red Red/White OHMS:75-90 DVA 25V or more
Red Stator
White/Green Green/White OHMS:500-700 DVA: 180V or more
Red Stator Adapter
WIRE Read To OEM RESISTANCE DVA
Blue Blue OPEN 180V or more
Blue (Each) Ground OPEN 180V or more
NO SPARK OR INTERMITTENT SPARK ON ONE OR MORE CYLINDERS:
1. If the cylinders are only acting up above an idle, connect an inductive Tachometer to all cylinders and try to
isolate the problem cylinders.
2. Check the trigger resistance and DVA output as given below:
Wire Color Check to Wire Color Resistance DVA Reading
Purple wire White wire 800-1400 4V or more Connected
Brown wire White/Black wire 800-1400 4V or more Connected
Purple wire Engine GND Open 1V or more (*)
White wire Engine GND Open 1V or more (*)
Brown wire Engine GND Open 1V or more (*)
White/Black wire Engine GND Open 1V or more (*)
(*) This reading can be used to determine if a pack has a problem in the triggering circuit. For instance, if you
have no fire on one cylinder and the DVA trigger reading for that cylinder is low ? disconnect the trigger wire
and recheck the DVA output to ground from the trigger wire. If the reading stays low ? the trigger is bad.
Note: If #1 and #2, or #3 and #4 are misfiring, check the trigger as described above. The trigger uses two coils to
spark four cylinders. #1 & 2 share one trigger coil and #3 & 4 share the other trigger coil. Also, the switch box is
divided into two parts. The #1 and #2 cylinders spark on one half, and #3 and #4 spark on the other half of the
switch box. If the trigger tests fine by the chart above, but you have two cylinders not sparking (either #1 and #2 or
#3 and #4), the switch box or stator is bad.
3. If you have two cylinders not sparking (either #1 and #2 or #3 and #4), swap the stator leads end to end on the
switch box (Red with red/white and blue with blue/white). If the problem moved to the other cylinders, the
stator is bad. It the problem stayed on the same cylinders, the switch box is likely bad if the trigger tests within
specifications.
4. Check the DVA output on the green wires from the switch box while connected to the ignition coils. Check the
reading on the switch box terminal AND on the ignition coil terminal. You should have a reading of at least
150V or more at both terminals. If the reading is low on one cylinder, disconnect the green wire from the
ignition coil for that cylinder and reconnect it to a load resistor. Retest. If the reading is now good, the ignition
coil is likely bad. A continued low reading indicates a bad power pack.
PLEASE post test results prior to getting any parts , This is a general guide and sometimes results can take you the wrong way due to other bad parts effecting test results !
ok i did number 1 and its started. now im in process of figuering where the short is so far no luck. thanks for your help
kend301
Please open a new thread for your boat , in the mean time , reconnect the black/yellow to the switchbox then unplug it from the rev limiter and chack for spark .. post up results in a new thread .
