Split in splash rail
Colin Varley
I have a 1990 Smokercraft 16+ foot bowrider. A split opened in what I will call the splash rail, starboard side - keel like shape that runs the length of the boat at the waterline. Boat takes on water very quickly and will obviously require repair. Anyone with ideas on why this occurred and how best to repair so that boat is safe to use?
Bob_VT
Re: Split in splash rail
Weld..... a split that long will not survive with any other repair
Colin Varley
I should have mentioned the split is approximately 30 inches in length at this time
Bob_VT
If it's a split in the aluminum having it welded is the only way. Post some photos ..... this is the first time I have heard of an aluminum split just happening
Colin Varley
Here are the photos.
Bob_VT
Find a shop that does aluminum welding and then you will have to touch up with paint.
Grand Larsony
Had same issue on a 1985-ish Smokercraft from prior owner where it rubbed on a dock all season. Weld it as others have said. Will be ugly looking. Very.
