Spline grease
shadowrider
I think I forgot to grease the splines on my gen2 LU. What is the main purpose of spline grease, To keep water out for future disassembly and friction/wear reduction. Hoping it will b ok for a season.
tpenfield
Re: Spline grease
You mean the propeller shaft splines? . . . Makes it easier for the prop to come off when you want it to.
shadowrider
Re: Spline grease
Driveshaft slines after water pump service
MarkSee
Re: Spline grease
On the engine coupler you should have at least 1 zerk fitting you can shoot some grease in, rotate the shaft, shoot some more.
That should help some.
Mark
shadowrider
Re: Spline grease
did that, how can you rotate the shaft, by bumping starter?
MarkSee
Re: Spline grease
That would be the easiest way for sure.
Mark
shadowrider
Re: Spline grease
How is the coupler zerk going to get grease to output shaft on top of lower unit ? Does not sound like we are on the same page.???? I dont know for sure
Don S
Re: Spline grease
Which splines are you referring to?
attachment.php
MarkSee
Re: Spline grease
I was working off you using the term "spline grease" which is in the name of the grease used for A, not B/C.
Engine Coupler and Spline grease
Don S
Re: Spline grease
The grease keeps the splines from wearing out, plus it keeps them from rusting.
cr2k
Re: Spline grease
On a gen II spline B in bathed in oil and needs no grease.
MarkSee
Re: Spline grease
The manual does show coating the B splines in 24c before assembly.
Maybe that's what he was asking about.
Sorry the picture is a little small but you can see the reference to using 24c.
Mark
