spitting out idle air bleed jet ???
scottg
have been trying to track down way this '86 120HP<br />Johnson runs rich at idle for a while now. Over the weekend I noticed when I took of the air box that it was very wet on the inside. When i started it with the air box off i noticed it was spitting gas - one spit about every 3-4 seconds from each of the 4 carbs' idle air bleed jets. <br />what mibht cause this???
Trent
Re: spitting out idle air bleed jet ???
Check your reed valve for damage.
scottg
all 4 cylinders are spitting out the air bleed jet<br />not the throats. would one brocken reed cause problems in all 4 cyliners?
