speedometer question
crlbon
I was told by the person who installed my Evinrude motor that there is wiring for a speedometer. I cannot, however, find a speedometer that is available. Any ideas?:confused:
kick bass
Re: speedometer question
What year and size evinrude? Are you sure he said speedometer?
raven7
Maybe he meant to say "Tachometer".
Silvertip
Honorary Supreme Mariner
Speedometers are not electric other than the internal light which simply gets power from the NAV/ANCHOR switch. Speedometers have a plastic tube connected at the back which runs to the back of the boat and connects to a pitot (speedometer pickup) mounted on the back of the boat or it may connect to the pitot built into the lower unit of the motor. As the boat moves through the water, water pressure compresses air in the tube which unwinds the bourdon tube in the speedometer which makes the needle move. Speedometers are generic and you can get them at any store that sells boating supplies -- even some Wal Mart stores and farm stors carry them.
If you mean tachometer (rev counter) then yes, the control box has a connection for a tach. Tachometers are also generic unless you need the system check indicators and even then, Faria and Teleflex can provide them.
crlbon
thanks for the advice, I think you may be right
Silvertip
Evinrude offers a full set of gauges for all of the mid range and higher motors. They are also available aftermarket. The only term he incorrectly used was "wired" if he really was talking about a speedometer without system check indicators.
