Speedo Question Not Addressed B4?
Shredder56
I have a 2002 Bayliner with VDO gauges...
The Speedo quit workin...The floor in my boat was soaked ...narrowed it down to the "tubing" coming from the outdrive. Skipping forward...I have a Part that at the end of this "tubing" changes from air pressure to I'm guessing an electrical impulse. It has a tubing input on one end and a 3-prong socket that plugs into the speedo harness. I can blow thru this part which leads me to believe that the water would works its way all the way to the speedo.If I understand the operation of "most speedos" they work on the air pressure "within" the tubing. Water Should never reach the speedo itself. Correct? So has anyone ever heard or seen something like this? I have e-mailed Bayliner...of course..no response. Been on the VDO website can't find anything that looks or works like mine..Any ideas out there?
Direct E-mail or post reply EDIT: emails not allowed for your protection. TD.
Chris1956
Honorary Supreme Mariner
Re: Speedo Question Not Addressed B4?
Yes, most speedos work on air pressure. Water can and does reach the speedo, depending on installation, speed and other factors like air leaks. Probably your electrical-pressure changing device is some sort of transducer. It may put out a variable resistance, or a variable voltage. Does it have a ground wire on it? How about a +12VDC supply as well?
Why not replace it with a standard unit that looks similar to the original?
