Jacalore
- Jun 3, 2013
- 457
Speedo doesn't work, checked out pitot tube, it's cracked on the end. Ordered another, replaced defective one. Q: Is the rubber hose length critical? The new pitot tube connection must be a bit higher on the transom, cause what was a straight run, now has to be rerouted to take up extra slack. I was gonna cut it, but two things - the end is flared and snaps onto the tube barb securely, may not fit w/o flair. And maybe the hose length is calibrated to the instrument?
