Speed odometer stopped working 2006 Q4 SK/FS
redrocker1962
was onu in the lake late yesturday very smooth I was running trim almost full up abouk 53mph and my speedometer all of a sudden stopped // my first boat I know the speed is picked up off sensor // where is the sensor ?and what could be the problem
it has the V6 4.3 merc cursier 230 hp power plant
Thank you
Eddie/Redrocker1962
yourboatmyboat
Re: Speed odometer stopped working 2006 Q4 SK/FS
With your drive all the way up run your hand up and down the back side , there will be a knotch , that will be your pickup for speedo. Make sure no trash is in knotch
redrocker1962
Checked that no trash went out on the water rode for about 4 hrs noticed the boat not handleing right very sluggish when i would come out of a hard turn the boat would want to continue in the direction (going past the straight point and wanting to continue past). when i trailered the boat and removed the drain plugs steady water for aproximately 5 min could the speedometer and this problem be related??
timdan94
sounds like your pitot tube line that goes from the motor to the spedo had a connection come off or has a hole in it.
