Re: Specs on 1992 70HP Evinrude
Oh, yes. If your motor is the type with a separate oil tank, you simply put the oil in that tank and it is automatically mixed with the oil. However, you'll want to make sure that the pump that pumps the oil to the engine is operating properly.<br /><br />To do this, you can simply prepare the 50:1 mixture, as described above, and run that, with oil also in the oil tank. Once you see that the pump is operating by the oil in the tank being used, you can discontinue the oil mixture with the fuel.
