FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Where does the distributor ground attach? i just ran my new engine and it's not running right. And I do have and extra black wire with a loop terminal right by the distributor.
This ignition originated with a 1997 4 barrel 350 Mag which later had heads done at a Mercruiser shop. I bet they used the 10-32 x 1" hold downs then and left off that ground.
There is a ground on the distributor by the ECM and knock control module. But since the distributor is made of aluminum I am going to do the 1.25" through-bolt and add that ground. Aluminum isn't the best conductor.
