Speakers on Swim Platform?
scca vette
I am getting ready to fix the holes the previous owner put through the back of the swim platform for the redneck exhaust. I have been kicking around the idea of mounting speakers in this area instead of patching the holes. I am not one for having a radio blasting when anchored and figured if the speakers were out back I would be ble to have the volume low and still be able to enjoy music when swimming or just lounging around.
My question is does anybody see this being a bad idea keeping in mnd I will be using marine speakers?????
Here is a pic of the NICE exhaust that I will be removing andd placing speakers in its place.
Triton II
Re: Speakers on Swim Platform?
That exhaust is fantastic! Not!!! If you sealed the speakers inside the transom... ie glassed/5200'd a waterproof box behind each speaker it might work, but the longevity of the speakers would be severely diminished if you slow down too quickly - even full on marine speaker cones break when hit by a wall of solid water! Why not use a couple of bracket mounted box type speakers in the stern area and when you want to have a swim, undo the brackets and sit them on top of the lounge back rests. Just a thought.
TII
BigBoatinOkie
If you want them there I don't see what it would hurt. The speakers will probably get wet alot and be exposed to the sun, but they should last a while as long as they don't get totally swamped. I wouldn't put in really expensive speakers though. That way it won't be a big deal when one needs to be replaced. I've also seen some brand new boats that have a hard wired remote control mounted by the swim platform where it can be reached easily from outside the boat. I think that would be a good idea too if I was mounting speakers back there. Are you routing the exhaust back through the hub?
scca vette
I am looking at using a PYLE stuff and the speakers are like 30 bucks. I was looking at the remote option however the radio I am looking at buying has a wireless remote. YES! I am putting the exhaust back through the outdrive so it is QUIET! I like the sound of thru hull (real thru hull, not this mess) however I want this to be a comfortable boat that people can carry on a conversation in.
scca vette
Yea you are thinking the same as me. I was also concerned of the backwash when letting off fast. I was hoping if I bought speakers with tight mess covers it would help break up the water slaming into the speakers.
Maybe it is worth a try, worse case senario is I will have to remove the speakers and fix the holes later.
Shife
TII
The Aussie hit the nail on the head. Speakers are no more than an open metal frame with a thin membrane in them. If pooped from astern the speaker cone will not be able to withstand that kind of pressure, will rupture, and become a point of ingress for water to enter the hull.
In calm conditions no big deal. In rough conditions a really really bad idea.
