spark problems
schmaky1
Need help trouble shooting. I recently put in a new ignition module in my 70 hp Chrysler and can't seem to get a spark through the spark plugs. There is power going into the module but no power going to the distributor and spark plugs. The distributor looks fine, spark plugs are new, spark plug wires are new....I have run out of ideas on what could be the problem, any ideas would be greatly appreciated.
Oldsaltydog
Re: spark problems
Is there a way to test the ignition module, to make sure it's OK?
novicetech
Re: spark problems
You didnt say what year, the first thing I would is clean all of the connections going to the distributor and replace the points if the motor has them. Did you replace the coil also? There is a great ignition troubleshooting section on chryslers at www.outboardparts.com
