BottomFeedersFishing
Thread starter- Joined
- Dec 5, 2015
- 10
I have a Johnson 25hp tiller motor. Model Number is J25Teeda. push button start, single carb, 2 cylinder. For the past couple months I have been working on this motor that was sitting for a couple years. Have done the works to it. New parts include: Water pump kit, carb kit, fuel pump kit, all new fuel lines, new tank, new tank to motor line with squeeze ball, push button start has been replaced, multiple sets of spark plugs, and new battery. Had the motor running well for awhile but recently it has started acting up. We put in the river and had a little bit of trouble cranking the motor. After it coughed and sneezed a couple times it finally cranked. Headed out on the river I went to plane out and it wouldnt go but about a third throttle even with the tiller handle wide open. Pulled closer to shore anchored off fished then went home. since then I started tinkering.
I have done the following:
-took carb back off (after being completely rebuilt already before these problems started) found nothing but a shiny clean carb with the float set right and all jets clean and clear. Needle was set right with float and isnt sticking.
-checked to see if I am getting fuel to motor and I am. Carb is OK. Reeds look good also while i had carb off.
-carb is adjusted right and throttle flap opens wide open also when handle is WOT.
- Compression is 118 on both cylinders
-I have spark on bottom cylinder but not on top cylinder. Checked with air gap tester. Switched coil packs around( 2-cylinder motor) with matching plug wires and still no spark on top cylinder
Now im stumped. Was thinking power pack but wouldnt I have no spark on both cylinders if it was a power pack???
Any help is welcome. Have a tournament coming up and need the motor running
Bottom Feeders Fishing
