spark plugs outboard motor
1946Zephyr
Re: spark plugs outboard motor
I would say "when they get dirty." It all depends on how much use you have each year. If you only take your boat out once a year, then you'll probably get several years use out of them.
boobie
Pull 'em and look at them. When the gap is getting wider and the center electrodes are getting rounded off, replace 'em.
sschefer
If your a typical basser you're running hard between holes and then shutting down. Sometimes the engine cools down between runsa and sometimes it doesn't. That's hard on plugs.
Plugs are cheap keep a spare set on a hand and replace them every 50 hours of run time. The normal rule of thumb for boats is every 100 hours but that is just a rule of thumb with the idea of never being stranded as a base. It's not scientific and easily argued but it's also a safe rule to follow.
emdsapmgr
Most folks put 30-60 hours a year on their outboards. Anglers who do tournaments may do double that. Still, in the scheme of things, that is not a lot of hours. Plugs in normal service should give years of trouble free operation. Replace them when you feel a miss at high speed.
