Spark plugs for my 1973 65 hp Triumph
CIMBill
The manual recommends the gapless plug Champion UL-77V. Which is better; the gapless or the gap?
F_R
Honorary Supreme Mariner
Throw those surface gap plugs into the deepest hole in the sea. Use Champion QL77JC4 plugs gapped 0.035"-0.040".
oldboat1
I never contradict a man who wrestles alligators, but might add a suggestion. I would get an open air adjustable spark tester and test the ignition system before deciding on plug gap. I believe your motor would produce a 5/16 (?) spark if in good shape, although maybe less. If the ignition is in top shape, a wide gap on the QL77 plugs is the route to go. The weaker the ignition (age affects us all), the narrower the plug gap. A .030 gap might be preferred, for example, if the ignition is showing its age.
oldboat1
^appreciated. I would consider reducing plug gap if ignition output is weaker.
