Spark plug wires
chicagotrader
Hi - I cannot for the life of me figure out how to remove my spark plug wires from my 1994 yamaha 115 hp 2 stroke ! I have the shop manual but it makes no mention. Anyone know how ? Many thanks
I know on some motors the wires screw into the distributor cap / coils.----Not sure on your motor.-----Why do you want to replace them ?
chicagotrader
just having constant cold starting problems, trying to eliminate inexpensive possibilities. No distributor on this model.
Well , yes I know there is no distributor on your YAMAHA-----Review your starting procedure.------I do not believe plug wires will help one little bit !!------Explain how you try and start your motor in detail.----And how long have you owned it ? .----Any trouble shooting done ???
boscoe99
Are you talking about removing the spark plug lead from the spark plug itself?
No----- he wants to replace plug wires in the hope that it will fix " cold start " issues.
robert graham
More likely the cold starting issue is something with the enrichening device and/or your starting procedure......leave the plug wires alone for now...
boscoe99
I get the part about the OP wanting to replace the spark plug leads. What I am not getting is his question about how to remove them. Remove them from what or where?
The cap from the spark plug?
The cap from the ignition lead?
The ignition lead from the coil?
The coil from the motor?
Or ???
GA_Boater
Have you checked for spark on the plug end? If you have a good, strong spark that jumps 3/8" or more, look for some other cause.
What is your starting procedure? Maybe it needs to be different for a cold start.
Sea Rider
Clean plugs, check if gaped to specs or replace all of them and test again..
Happy Boating
