Spark plug wires
Traveno82
I have a 1965 75hp johnson super seahorse. V4AL-17S. I have a couple questions the the electrical aspects of the motor. I need to replace the ignition coil and spark plug wires for sure. The motor hasn't ran in years and I'm trying to get it and the Larson it was attached to going again. Any suggestions on either of those parts or anything else I should look into before throwing a bunch of money at it? I have the lower gear unit and extension removed at this point.
Thanks in advance!!
Lee
Honorary Supreme Mariner
Sparkplug wires are threaded into the cap.--------Do a compression test before you spend any money !
Chris1956
Some of the ign coils for those older V4 'rudes were very expensive. You might check it out. Do you have battery/coil ignition or magneto ign?
F_R
Yep, 379569 coil is outrageous at about $200+. It is battery ignition (similar to an old car of the vintage). That should give you some ideas.
The plug wires screw into the cap. Replacements are available here at iboats. But you have to assemble the threaded ends to the wires. To do that as originally intended, you need a special crimping tool. But that too, can be worked around with some soldering.
F_R
As originally set up, the coil was fed through a one-Ohm resistance wire built into the external wiring harness. Necessary to prevent burning up that new $$$$ coil. Or to be taken into consideration if using a substitute.
Chris1956
When I converted my '59 50HP V4 to battery/coil ignition (due to the price of a new magneto coil), I used a ford coil from my '64, along with a condenser from the same car. It worked well, but since I had no charging system, I needed to charge the battery a lot.
Traveno82
Thanks everyone for the responses!! $200 is way out of my price range for that coil. I've heard/read somewhere that you could use an ignition coil without a resistor in its place? I ordered one for $18 so if that's not the case I'm not out much. My neighbor had a compression gauge but when I removed the motor from the boat I left the wiring harness in the boat(bad planning with snow coming). My thoughts/direction are to first get it operable, not necessarily a restore in mind. Would just like to get it and the boat going to take my kids and dad out in it as he was the one to buy it for us. Would I be ok to simply hook the starter up directly to the battery to check compression without the entire harness(guessing it wouldn't turn over anyway without everything else hooked up) Any concern doing so with lower unit/extension/water pump/drive shaft off?
Thanks again!
Lee
F_R
No problem, the starter will turn it over for checking compression by using jumper cables directly to starter and engine ground. But be very careful doing any other form of partial hookups. There is danger of damaging the charging system.
Traveno82
Sounds good!! I'll give the battery a good charge today so I can get more accurate results. Hopefully I can get ahold of the compression gauge asap as I'm getting some ambition going!!
Thanks,
Lee
Chris1956
Lee, Since I was not an expert on battery/coil ignition, I thought it prudent to use the condenser that was paired with the coil, from my old Ford, on my 'rude. I do not know if different coils need different capacity condensers, or whether they are all .25 mF, like my Ford condenser. Were you able to order a condenser with the coil?
Traveno82
Here's the coil I purchased. I'll do a search and see what I can come up with for condenser options. I'll have the compression gauge later today and will get it done tonight or tomorrow.
Thanks,
Lee
Traveno82
No Title
I feel like a real idiot but I cannot get this starter to turn over! Battery is good, jumper cables are good, 12.8 volts tested at the end of them. I don't know why it turned over when I had it on the boat and now I cannot get it!! I tried pulling it but that's a big pain in the butt and the results are pretty lame on my part!! Any help would be great!!!
F_R
So you are using jumper cables directly to the starter and engine ground, right? Not many possibilities there. Bad cables, bad starter, bad connections. Check your voltage between starter terminal and engine ground while connected and in no-crank situation. If you have 12V +/-, then it is a starter problem. If low or no voltage, a battery, connections, or cable problem. I'm betting on connections.
Traveno82
Yes jumper cables. Positive to post on starter and negative to grounding bolt on head(where ground wire usually connects). I'll do the test you mention get back to you, thanks for the quick response!!
Lee
Traveno82
Ok, so I tried it today again. Used F_R's suggestion on checking volts across. Nothing. Checked battery, nothing. Disconnected cables and checked battery again. 12.4 volts. Double checked connections, retried. Same thing. Battery and jumper cables show 12.4 until I touch them to the ground and starter, then shows 0.00v. Bad battery? Can I hook it to my vehicle's battery when the car is running or should I remove it or at least disconnect it from the cars electrical system? Out of time for the day as I'm headed to work, but will check in later.
Thanks again!
Lee
Chris1956
If the voltage goes to zero when connected to the starter, either the battery is bad or the connections are still dirty. Put the voltmeter on the battery post themselves and see what the voltage is after connecting the jumpers. If the battery post reads zero voltage, it is likely a bad battery or a massive short in the starter. That massive of a short in the starter would be unusual, but it is possible.
Does the starter spin by hand?
To be safe, I would jumper from the car battery, when the motor is off. If the motor cranks, get another boat battery.
Those are a geared down starter .--------A prudent owner would take the thing apart to grease the gears and bushings.-----------Inspect the brushes and all.
