Spark plug wires fell out of coil......
stone_holder
i have a 1976 70 evinrude and when i went to move the plug wire out of the way so i could change the plug , the **** wire fell out of the coil. Do the plug wires just shove into these coils or are they supposed to be permantely attached? Thanks for the replys.
12Footer
Re: Spark plug wires fell out of coil......
On that coil, it is suposed to be epoxyed-in.<br />On older ouboards (up till the early 70s), they were held in place with screw pins,solder,and rubber grommets.<br />It sounds like you need a new coil. The one you have could be re-connected,an HV epoxy poured-over it, and placed in a plastic bag to go in the emergency repair kit (it will get you home,but I wouldn't rely on it being a permanant fix).<br />My father in-law had an engine like yours, and the coils failed often.Given the price (I forget,but do remember we couldn't afford gas after buying new ones), I think you better brace yourself for sticker shock.<br />At any rate, good luck with the repair.
stone_holder
Thanks 12footer.....i guess i'll head to the bank for a loan.....hahaha...thanks again.
Easttxhunter
I have a 1975 johnson 70hp stinger where i just replaced te coils. They were 31.00 a piece from local dealer and the plug wires screw in. Not the best design they ever came up with. I also used automobile connecters on the other end of wires as they seem to keep corrision out and give me better contact.
