Re: spark plug threads
Although installing a Heli-coil is a fairly simple task, you can get in trouble pretty easy with alluminum (the tap getting crooked). The kit should come with drill bit, tap, coils and some come with a Heli-coil extractor tool. If you have access to a drill press, this would help you greatly. 1st you punch out the hole with proper drill bit then tap the hole. In order to insure your tap gets started straight you can chuck up something in your drill chuck that come to a point. Most taps have a "dimple" or center in the drive end for this guide thats in your chuck to fit into. Have a friend apply a little pressure as you tap down through the head. The rest is all gravy. I pulled both heads of of my '85 140 h.p. in about 20 minutes.
