spark plug threads in block
I just bought a project motor, a 1967 mercury 50hp short shaft.When I got it home I realized that one plug hole has bad threads in it and another one has a larger size thread than the plug.My Question is are these inserts replacable or since there is no removable head on these motors, did I just buy a parts engine?
mthieme
Re: spark plug threads in block
It's possible someone before you use a helicoil insert to rectify a previous thread issue.
jimg984
NAPA Auto Supply has the inserts and tool you need,,, good luck
Chris1956
You should pull the crank and pistons out of the cylinders, and drill, tap and install the solid inserts with some epoxy.
jimg984
Yes, Chris has given you the correct producer for taping for insert,,, but can be done with removing crank and pistons a stiff heavy grease applied to the tap and erea to be tapped will catch most of the metal,,also as the tap turns it moves metal to the outside of erea,,, also you may position the engine so the spark plug hole will be pointing down,, ( redneck and shadetree method lol}
Chris1956
Jimg has recommended a standard practice for the repair. The problem with this procedure is that some slivers of aluminum may get into the cylinder.
Laddies
Banned
The process that jimg describes is the one Mercury recommended about 1969 and we have used it ever since with no problems.
jeff_smith_0423
I recently did one - any shavings that get in the block can easily be removed with compressed air
Thanks guys , just realized that there were replies, I thought that replies would show up in private messages, so I thought no-one replied.It turns out the previous owner or owners have tapped these holes with two different styles of inserts, one a helicoil from NAPA and the other I found at princess auto. Both purchased for under ten bucks ( alot cheaper than the ford kit). The compression seems okay, hard to check with a pull start.I've added a 1974 distributor and now all I have to do is find a coil and switch box and fire her up.Thanks again for the replies!
kandil
The safe way to do it is to take it to a shop to braz new aluminum to the whole and re thred it or find a used one.
Helicoil are very dangerous for spark plugs you can kill your self if the plug projects out from the compression inside the Cly good luck and be safe:)
jimg984
the insert from NAPA is not a helicore,,,,,,,,,, it s threaded male/female insert
