Spark plug gap
richsbca
Hello I have a Evinrude 85 hp 1975 and would like to know a good plug to use and the gap. I currently have autolite 2634 in there with a gap of .040+. <br /><br />I am wondering if the larger gap would contribute to a issue where the power would increase, as if a cylinder kicked in, at about 20mph or so.<br /><br />Thanks<br />Rich
dukewichers
Re: Spark plug gap
First off get those trot line weights out of your engine. Champion should be used, I think the correct plug is QL77JC4 if a resistor is wanted or drop the Q for a standard plug. Gap should be 0.30 in. <br /><br />Good Luck, <br /><br />Bayou Thunder
richsbca
Re: Spark plug gap
Originally posted by Bayou Thunder:<br /> First off get those trot line weights out of your engine. Champion should be used, I think the correct plug is QL77JC4 if a resistor is wanted or drop the Q for a standard plug. Gap should be 0.30 in. <br /><br />Good Luck, <br /><br />Bayou Thunder
richsbca
Re: Spark plug gap
Sorry about the last post, I kind of blew it!. Do you mean .030 on the gap?<br /><br />Thanks for the quality help!<br />Rich
jy118lfd
Re: Spark plug gap
Ql77jc4 is a inductor type suppressor not a resistor. They are the best plugs for your motor. Gap at .030 or .040 if you troll alot. I have them in my 150 83 v6 and have about 75hrs on them this year about 60 hours trolling and they will not foul. Provided the motor is in a good state of tune.
