Spark plug difference?
rodknee1231
Went to get plugs for my 1973 johnson 135 today. I replaced my 85 power head with a 135 last year. The plugs in the 85hp were ql77jc4 the ones recommended are ul77v surface gap which no one has is there a difference do I need to run a surface gap in this 135 or will the ql77jc4 be ok also what should they be gapped at ? Thanks
emdsapmgr
I always run the surface gap plug in those engines which specify that plug. All Bombardier dealers stock those surface gap plugs. Most auto parts stores can get them even if they don't normally stock them. The 73 85 hp also spec'd that surface gap plug from the factory-not the QL77JC4.
F_R
Honorary Supreme Mariner
Actually, the factory specifies both plugs. The surface gap for continued high speed running and/or the gap-type for low speed or wet-fouling problems.
Vic.S
ITYWF that the latest recommendations are L77JC4 or QL77JC4 for the 85 hp and UL77V or L16V Surface Gap for the 135hp
The recommended gap is 0.030" for the conventional plugs
rodknee1231
Well I'm in the process of a break in so if the regular one does better with fouling I'll run it then switch to a surface gap. The ones I got should work though correct?
F_R
So you have QL77JC4, right? Those would be the correct gap-type plugs if that is the way you choose to go. The "Q" denotes an inductance type radio suppressor (suppresses static or "noise" on nearby electronic equipment). I'll say no more on the subject of gap vs surface.
