Spark for 1962 Evinrude lark IV (40hp)
J.R.
I have a 1962 Evinrude Lark 4 40hp outboard
Manual Shift, (35531M)
2 cylinder
I was having issues trying to figure out how to properly connect the ignition switch, the motor started fine a few times once i finally figured out how the wires ran per some other iboat forums and wiring diagrams, The motor now no longer starts so when checking the iissues i found that I no longer recieve and spark at all to the Plug Wires at all now.
1. What causes loss of all spark through the plug wires?
2. Is there a way to test power to the coil, w/o removing flywheel?
3. worst case is there a diagram anywhere on the net i can find to replace the coils and points?
tashasdaddy
Re: Spark for 1962 Evinrude lark IV (40hp)
you skipped right over the answer, TOP SECRET FILE, 1st post in this forum.
J.R.
Quick question
If I placed the magneto wires in the wrong place on the ignition and caused them to get hot very hot what would i have damaged in the firing system on the motor.
My assumption is I may have burned coil wire into
however im extremely new to boat motor repairs
tashasdaddy
if you sent 12 volts directly to the coils, they will probably look like these.
J.R.
Thank You ever so much for prompt response I will be getting the coils, points and condensors changed as soon as i can afford it.
J.R.
