spark advance link broken
oldphart120
My '89 Johnson 120 V4 looper has a broken spark advance link, I think that's what its called. Its not on any parts diagram I've found, probably obsolete. I found a few on feeBay but they aren't the same as mine. Any body have one or know where I can find one? I tried to post a picture but I'm having trouble with that. Second question; What do I use as a pick point to remove my O/B from the boat? Is the crank permissable? I can fabricate a lifting plate to bolt to the flywheel or an adapter to screw on to the crank end. That OK? BTW the o/b weighs about 365 #'s.
F_R
Honorary Supreme Mariner
I believe the parts are shown on the powerhead page, items 81 through 85. 81 is the assembly 432095. Yep, obsolete.
Yes, the crankshaft or flywheel is where you lift. The factory had a lifting tool that fitted there. Just make sure you make it strong enough.
emdsapmgr
Many of these obsolete parts may still be available as new-in dealer stock throughout the U.S. Any Bombardier dealer can inquire their proprietary in-house on-hand software for you. It shows what new stock other dealers have still on hand. For instance, 4 new pcs of the part number 432095 is on hand at this Bombarider dealer. Contact them direct to purchase.
US BOATWORKS INC930 OSAGE AVEKANSAS CITYKS661051850913-342-0011
oldphart120
Thanks for the reply. I thought I had seen that somewhere, but I had to re-check cuz my old brain is full of holes. I've got a chunk of 4140 HT to make a lifter with. Time to fire up the lathe.
oldphart120
US BOATWORKS INC930 OSAGE AVEKANSAS CITY[/TD
[TD]KS
That's huge, thank you very much.I believe there is a dealer here in West Bend, WI. I'll call KC also. They probably want an arm and a leg for it tho. If so, I can replace the broken threads with a brass part.
oldphart120
WOW! I just talked to the KC dealer. He has 4 used ones for $175 a piece, an arm, a leg and other body parts. I'm glad I have a small machine shop. I could make those things and sell them for a nice retirement income. ;-)
