chumbucket
Thread starter- Joined
- Oct 12, 2001
- 320
What's the difference in the ceramic heater and plain type heater 1500 watt ??
I'm curious - what energy form is the other BTU's consumed by, if not given off as heat?<br /><br />light? vibration? <br /><br />I would assume the orange glow i.e. light... although it's not very bright...<br /><br />1000BTU is about a 300Watt loss..that orange glow couldn't be 300 watts ...<br /><br />I always thought electric heaters were pretty much 100% efficientOriginally posted by Stratocaster:<br /> The difference is efficiency. ceramic elements are very efficient at turning electricity into heat. A 1500W ceramic element will give you about 5200 BTU. A plain-jane 1500W coil about 3500-4000 BTU. BTUs equal heat, the more the better.
This is not true. All resistive heating elements give off the same amount of heat - approximately 3.4 BTU per watt. The only difference between the two types of heaters is safety and how well they distribute the heat throughout the room.Originally posted by Stratocaster:<br /> The difference is efficiency. ceramic elements are very efficient at turning electricity into heat. A 1500W ceramic element will give you about 5200 BTU. A plain-jane 1500W coil about 3500-4000 BTU. BTUs equal heat, the more the better.
