HI all, I am new in boating and fishing offshore.
I have a 2 stroke mariner 90HP (1998) and last weekend I went to a western port here in Melbourne (Australia). I went to very shallow waters (0.4m) by mistake and the engine practically was running in the mad. To the point that it was expulsing mud trough the water out hole.
Then, it was getting hot and a "bip" sound started. I turn off the engine and waited until it got a bit cold and moved it out the mud. I turned it on again and the water was flushing clean and the ?Bip? ended.
I went to many places later on at full speed. I did not have any issues and it was running very good.
I went home and flushed it as per usual and it was ok.
I tried to move the propela manually and hear a mild sound (like a cracking sound) coming from inside (around the arm between the propela and the motor head). I don't know if the sound was there before because I did not check it or it was caused by the mud.
Does anyone have a similar motor that can check if it has the same sound is coming?
What do you think?
Thanks in advanced if anyone can provide me with a point of view or help.
Thanks
Kerby
What do you think?
Thanks
Kerby
