Re: Soon to be new volvo 3.0 owner
Would have had the drive fluid changed this AM but I couldn't get the $&% drain screw off...
Test run report....
Wow, what a difference a day (and a 4th cylinder) makes. Seemed to run terrific, plenty of pickup and speed. I could have pulled a skier without problems. I suspect the plug had been broken for a long while. RPM's are now at WOT 3400 rather than 2300. The spec shows they should be 4300. If the tach is correct I still have work to do. I wouldn't have known any difference if I hadn't looked at the gauge as it was running that well.
Current problems/concerns/questions
1. loss of approx 1000 rpm. I should be getting 4300 approx
2. Still need to change outdrive fluid. Any tips for that drain screw? Seems as if it was soldered or cemented in. Gonna have to get a bigger screwdriver?
3. Still need to change fuel filter
4. Finally found the carb screen and will clean that
5. Prop....Should this be able to spin freely as in give it a push and it spins, or does it require finger tension to turn?. Mine requires force. I plan to lube this also.
6. Will get OEM plug and coil wires, along with rotor. Should I change the cap also?
7. At WOT I noticed the temp above 180 to close to 200 and steady then back to 160-170 at cruise. New impeller the other day.
8. Rpm's are erratic regarding the return to idle after running. Usually hang around 1000 instead of dropping back to 750. Worried about putting in gear at that rpm. Carb adjustment, or cable lubrication?
9. Gimbal bearing lube to come.
10. Is it possible that with all of the above maintenance I may regain those 1000 rpm's and run cooler?
11. On the Starboar side outdrive I see a single cable that runs inside and it appears that the rubber is split. What is this?
I now have 55 hours and the only maintenance done was the 20 hour about 3 years ago. The plugs had incorrect gaps and I suspect whatever maintenance done at that time was on the weaker side. Checking the outdrive fluid It is overfilled and cause for concern.
Sorry for the long diatribe and thanks for taking the time to read and offer any suggestions.
Test run report....
