i have an 91 chapparral with 2 bbl 4.3l mercruisier, thunderbolt IV ignition. it will start when its cold or if it has set awhile but if u run it and shut it off it wont start i check for spark at the coil wire to the distributor cap no spark while crankin on it but as u let off of the key it will spark. so i replaced ignition switch still no spark so i checked juice on positive side of coil has good volts while crankin and while settin with key on. checked and bypassed engine safty switches didnt make a difference. i replaced plug wires, distributor cap , distributor sensor, coil, and the ignition amplifier i am at a stand still cant figure it out but when its runnin it will run fine just dont shut it off or it wont start again for hours or next day. does anyone have any ideas that i can try? thanks
