somehow getting stuck
lilbuilder
So i replaced my crankshaft in my 59 evinrude 35 hp and put it all back together and when i went to test it, the flywheel was hard to turn and the starter had a hard time turning it, so i took the spark plugs out and it was just fine, then put the spark plugs back in and it was hard to turn again. Is this normal for not having fuel/ignition?
F_R
Honorary Supreme Mariner
It is supposed to have good compression. That is why they incorporated a compression relief on the recoil starter. But of course there is a chance that you screwed something up while you were in there. Why did it need a crankshaft replacement anyway?
lilbuilder
the compression is at 120 psi, unfortunatly supreme mariner i may have screwed something up i just dont know what. i sprayed wd-40 and it runs fine with just one spark plug in for a bit, then it gets hard to turn again, i have no gas going into it was strictly testing the coils to see if they were bad or if they would spark.
lilbuilder
after taking it apart again i realized the piston is hitting the spark plug so i changed it around and put the exhaust side to the exhause side and still the same thing.
