some newbie questions
nightmare318
ok the motor is a aq125b how do i tell if it has been winterized?
after that how do I unwinterize it?
the big red box on the front of the motor (heat exchanger I think) whats it for? and should it have antifreeze in it (looks like antifreeze in it to me)
thanks guys
nightmare318
Re: some newbie questions
one more question.. would a bad seal on the water pipes cause the motor not to pump water? the impeller is fine.
Don S
If it's on the intake side of the pump it sure will.
Don S
I'm talking about the intake side of the raw water pump.
nightmare318
im talking about the one circled in red
Don S
Nope, that's on the output side of the pump. The most you would get would be a water leak.
nightmare318
well.. any other reason it would not be pumping water? impeller fingers going the wrong way?
